o2 wiring
  • JK_E30
    • Jan 2007
    • 545
    o2 wiring
    Need some help wiring up my o2 sensor *correctly*
    Got this info from a google search..
    small green wire>>>>>>>>>>white
    small black wire >>>>>>>>>>black
    small brown wire>>>>>>>>>>white
    small yellow wire>>>>>>>>>>grey
    Then a guy on e30tech posted this:
    Originally posted by chris325ix
    I don't think that's right.
    the harness side black and brown are grounds and should go to the two white wires.
    the yellow wire is signal, which I believe is black on the sensor
    the green wire is +12v which I believe goes to the gray wire on the sensor.
    I'm not 100% sure (but pretty close) on +12v and signal, but the white wires are definitely grounds.
    I just want to double check. Can anybody help me out here maybe take a look at your own setup?
    Thanks.
    M50B25tu
