i've researched this but there is such a jumble of information and arguments in most every string it's not clear...
Are there any differences between an M50 NON vanos head and an m50 head that has vanos? I know there is the vanos "lump"...but seems like that front casing/assembly piece will unbolt from an OBD-I S50 head and bolt up to the M50NV head? I know the cams/trays/ etc will switch over between the M5X and S5X vanos variants
I had read the non vanos head had valves that are 0.5mm thinner? Any truth to that? Not sure that would make any difference anyway.
Basically...will a non vanos M50 head work in an S50?
Thanks
Thanks
