S50 loses power
  • lga714
    • 315
    S50 loses power
    Tonight I was driving to get some Mexican food when my car lost power for a split second, weird I said to myself. Didn't come back until I was heading back to my buddies house when it completely lost power for a good 3-5 seconds, I had the accelerator pressed the whole time it lost power. I pulled over and waited for the cars behind me to pass. Once they passed I put it in gear and drove straight to his house and turned her off.
    I'm at his house now, I'm just seeing if I can get any input on what's going before I head out again, my only guess is the fuel pump? Please help thanks.
    mtechII 5 lug S50
  • blackhawkimpact
    • 2415
    Vacuum leak? Have that problem on my car recently.
    • lga714
      • 315
      Shit, it's pouring rain down here and he doesn't have a garage or anything for me to check it out. Did it do the same thing on your car? Lose power then come back on?
      mtechII 5 lug S50
      • lga714
        • 315
        bump
        mtechII 5 lug S50
        • 99em1
          • Dec 2009
          • 200
          loses power how. turn off? dash lights go out? does it just stumble or what?
          • lga714
            • 315
            The motor would still run but the gas pedal was useless. Dash lights stayed on, everything else was fine. I'd just be cruising along going 40mph and all the sudden I hear the motor slow itself down, it was very strange. On my way home last night it did again but only for split seconds than it came back on again.
            mtechII 5 lug S50
            • Fusion
              • Nov 2009
              • 3659
              Been driving in the rain the whole time or is that just now?
              • FredK
                • 14762
                Is the car originally a 318is?
                • lga714
                  • 315
                  Well I have had the car with this motor for over a month, the past week it's been raining.
                  No a 325i/a, before it had an M50 now it has an S50.
                  mtechII 5 lug S50
                  • M-technik-3
                    • 18946
                    Water in spark plug holes shorting out to block.
                    • bloodshot-e30
                      • 1494
                      is it like a "cutting out" power loss "sputtering" power loss or "lunging" power loss?
                      cutting out could= vac leak (LARGE) coils, or fuel related problem
                      sputtering could= ^^ those plus shitty ground
                      lunging= knock sensors.
                      ^Back in the game^
                      BUILD THREAD: http://www.r3vlimited.com/board/showthread.php?t=201281
                      FS thread:
                      http://www.r3vlimited.com/board/showthread.php?t=214105
                      • e30s50dan
                        • Nov 2008
                        • 2076
                        It could be something easy like bad gas. ^^ any idiot lights like oil pressure or volt gauge jumping. Good luck
                        NASA
                        BMWCCA member
                        PCA member 25yrs
                        1991 318IS slick top
                        1997 M3 sedan
                        2001 325CI DD
                        “whoever turns the wheel the least, wins"
                        • 99em1
                          • Dec 2009
                          • 200
                          First, I'd take out the plugs and look at them. Only takes a few minutes. Check for any oil or moisture in the boots.
                          • e46s54dr
                            • May 2008
                            • 1059
                            Plus 1 on this! Happened to me in my old e46. When it hesitates for a bit, does your engine sound like a subaru also?
                            • lga714
                              • 315
                              Haha not really, it doesn't really hesistate the motor just starts slowing down. The only "hesitating" it does is when the gas is coming back on, but the car doesn't lurch or jerk itself but maybe that's because I was just cruising in 5th at 40mph.
                              Thanks for all your answers, I'll take a look at everything tomorrow morning when its bright out.
                              mtechII 5 lug S50
