M50TU Ford Injectors
  • bmw2002tiiagave
    • 501
    I was working on my swap yesterday and noticed that I have Blue Ford Injectors. I bought the motor with it. Is it ok to use on this motor? or should I try to find a stock injectors?
    Thanks!
    1972 2002Tii
  • 10Toes
    Me Father Was A Tree
    • Jan 2008
    • 61222
    I'm using the green ford 42lb fuel injectors.
    Find out what size the injectors are, and then see if your ecu has a aftermarket chip for them.
    • bmw2002tiiagave
      • 501
      alright cool. interesting enough, idk if this makes a difference, but apparently i'm running a M3 ecu, is it even compatible with the m50?
      1972 2002Tii
        • 37829
        Yes they use the same ECU. The chip is the difference.
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • bmw2002tiiagave
          • 501
          Found out I have Ford Blue # F1TE-D5A, according to turnermotorsports, they are 24lb injectors.
          They say it's not safe without a tune, is that true?
          1972 2002Tii
          • matt
            • 3731
            You definitely need your chip to match your injectors.
            "Safe" or not, I'm not sure. Your car is fairly likely to run like crap and waste a bunch of fuel with those injectors and a stock chip.
            • bmw2002tiiagave
              • 501
              Oh ok cool. I might just try to find a set of stock injectors for the time being then.
              1972 2002Tii
