I just completed my s52 swap and im using a getrag 260 I put a stock sachs clutch and pp and I have only minor upgrades.After the second drive I blew up my pp, any recomendation on an upgraded clutch? I have used clutchet in my vw with good luck ,spec with no luck just want to get some opinions on what others are running with a setup like mine.thanks
need some clutch help
I used stock sachs kit including throwout bearing for 325.the straps let go on the pp.I was not driving too hard either car shifted great no noise nothing took a hard corner and lost the ability to shift.the assembly looked good.only thing I cant figure out is why the pilot bearing was sitting in the pp when I pulled the tranny,it went in hard with a socket.
What bearing did it come with? My last kit came with a .002" undersized no named brand bearing made in china, that caused serious vibration around idle and wouldnt clear up to 3200 rpm.
Did the car have similar symptoms?
when I bought a skf bearing it fixed it. it was .002" larger than my pilot that came with my oem sachs kit.84 318I Delphin RIP
87 325IS delphin 24v Sold
89 325 Alpineweiss
Originally posted by 416stroker View PostWhat bearing did it come with? My last kit came with a .002" undersized no named brand bearing made in china, that caused serious vibration around idle and wouldnt clear up to 3200 rpm.
No noise ,honestly everything seem perfect until I could not shift.I think the pilot bearing most likely came out with the tranny since I never heard any noise at all.I believe I used the pilot bearing that came with the sachs clutch kit,says KBC Korea.Good tip though I will put an SKF in just for good measure.Im going to replace the clutch and pp with a performance setup since I really dont know what happened here.
Anyone have any experience with clutchmasters? thinking about the fx300
