Do i need to run a oil cooler?
  • wobbie
    • 396
    I am wondering if i need to run an oil cooler on my m50 and also what radiator is the best choice? The e36 m42 because i want the expansion tank built in.
  • etxxz
    • Feb 2006
    • 2085
    no... and either e30 or e36 radiators work... for an m50 specially.
    No more e30s for me.
    88 black BMW OBDII 332is dedicated track [sold]
    88 BMW OBDII bronzit 332is [RIP 03/08]
    91 BMW 325i [sold]
    86 Corolla 'Ae86' HB 20v trd [sold]
    http://youtube.com/watch?v=pTj7Hn9v5Rs
    • wobbie
      • 396
      even though it has one stock i wouldnt need one?
      • e46s54dr
        • May 2008
        • 1059
        The stock m20 was designed for the use of an oil cooler but the m5x and s5x engine didn't require one. So no, you don't need to run an oil cooler unless you want to. Keep in mind that you will have to buy a kit or find a way to adapt an oil cooler to your 25v engine. For simplicity, I would just avoid that route.
        • wobbie
          • 396
          ok thanks I dont want to run an oil cooled I just wasnt sure if it was necessary.
          • ck_taft325is
            • Sep 2007
            • 6880
            Originally posted by e46s54dr
            The stock m20 was designed for the use of an oil cooler but the m5x and s5x engine didn't require one. So no, you don't need to run an oil cooler unless you want to. Keep in mind that you will have to buy a kit or find a way to adapt an oil cooler to your 24v engine. For simplicity, I would just avoid that route.
            :giggle:
            Need a part? PM me.
            • Fusion
              • Nov 2009
              • 3659
              Not mandatory, but I would recommend one for track use according to my oil temp readings.
              I'll be installing one come spring utilising Dude8383's placement behind the passenger light (search for pics).
              I don't like the idea of an oil cooler somewhere down in front of the engine.
              Btw: any recommendations for oil cooler adapters other than the IE adapter? Best bang for the buck maybe...
              • wobbie
                • 396
                im not racing the car. Just driving it mostly as a show car.
                • Jand3rson
                  • 37587
                  Even the M20 didn't really need it, I knew plenty of folks who were running without one, just swapped to the eta oil filter housing, and no issues.
