I am in the middle of an m50tu into 318is swap and I will be using the g240.
Can I use the flywheel and the clutch from a 95 M3?? I know that fly and clutch from an shaved m50 or m42 works with g240 but noticed that s50 flywheel has a different part number. Does that mean diameter or thickness is different then the one off of m50? Does s50 flywheel have to be shaved on the back to ring gear like on the m42 and m50 fly? the I can not find any info on this after searching through 24v section.
I am on a strict budget and friend is giving me the fly/clutch off his 95 m3 and thats why I am not going the m20 fly/clutch route.
Thanks!
Thanks!
