Developed a misfire...it seems
  • dude8383
    • Jan 2005
    • 10387
    **Problem Solved, See post # 5**
    Hey guys,
    Tried searching around but didn't find anything too conclusive.
    For reference:
    M50B25 block, m52 crank, rods and pistons...2.8liter m50.
    I was driving a couple of hours ago and all of a sudden the car started to hesitate across the entire powerband, I kinda peddled it home. When I finally came to a stop the car sounded like it wasn't firing on all cylinders. There is some vibration as I accelerate, no symptoms on deceleration though (no fuel or spark right?)
    I was thinking to start pulling the coil harness to see if anything changes to narrow down which coil is the culprit. OR it may be a spark plug?
    Is this a proper method for checking a misfire?
  • 99em1
    • Dec 2009
    • 200
    first I'd pull the coils and see if there's water/oil/whatever in there. then pull the plugs and take a look at those too.
    and what motor? i'm guessing you didn't throw a cel
    • 325issguy
      • Dec 2005
      • 261
      Sounds alot like when I had a bad vaccume leak...
      • dude8383
        • Jan 2005
        • 10387
        i actually have a spare set of coils that i will try but first im going inspect before replacing anything.
        motor info added in original post, yeh no CEL.
        this is a pretty clear misfire, i doubt a vacuum leak could create something like this. i'll post up a video in a few.
        • dude8383
          • Jan 2005
          • 10387
          Problem solved.
          MrSlacker came by and gave me a hand. I started with coil/spark plug 1, spark plug was a little oily but the coil itself looked fine. I replaced it with a spare anyway. Slacker started it up and the problem coil immediately made itself known...I saw the spark against the valve cover.
          Pulled coil # 5 and found this:
          I guess its time to replace all 6 huh?
          • ck_taft325is
            • Sep 2007
            • 6880
            I wonder if that's what's wrong with my S50... mmmm.
            Need a part? PM me.
            • 99em1
              • Dec 2009
              • 200
              cool. i always wonder if new coils would make a difference in mine. can't justify new ones though till i know they're toast. if it aint broke... and all
              • ZM Blue Devil
                • Dec 2006
                • 13836
                Denis, I have a couple of NOS coils, let me know.
                Levent
                %20levent@gutenparts.com
                Ladies:
                • samiam3356
                  • Jul 2009
                  • 1901
                  Thanks for sharing how you fixed it. Hate when I see these threads with no resolve.
                  Originally posted by Roysneon
                  $5 shipped?
                  Originally posted by MarkD
                  You are a strange dude, I'n not answering any more posts from you.
                  • dude8383
                    • Jan 2005
                    • 10387
                    well i purchased my coils used but i will purchasing new ones after this. generally if one goes bad then the others will follow suit sometime after.
                    no problem man, i hate seeing threads that don't have a solution either!
                    :up:
                    • audiphile
                      • 13
                      I logged in just to say that sometime after can be anytime from today to never, just like when you get them new. save your money and buy just 2 spares :)
