506 DME on M50?
  • bmw2002tiiagave
    • 501
    506 DME on M50?
    I've got a 94 Vanos M50, will a Silver 506 DME work with this motor? Also, does is have EWS?
    1972 2002Tii
  • matt
    • 3732
    The stock chip in the 506 will be for an S50, but it should run. It *should* not have EWS. YMMV.
    • bmw2002tiiagave
      • 501
      ok cool thanks. having problems starting the car thats why. I took the motor from a previously running swap car with the same harness, 506 DME, and motor and it cranks over but doesn't start in the new shell.
      1972 2002Tii
      • zenn0ne
        • Jan 2009
        • 119
        Check to see if you powered the fuel pump also check the fuel line to see if they're in the correct way just for piece of mind
        sigpicBEST OF BOTH BOOSTED WORLDS
        • e46s54dr
          • May 2008
          • 1059
          I have a perfectly working red label 413 dme for 80 shipped if you need one. Thought I'd share.
