S50 Swap List; missing anything???
  • Overlord475
    • Dec 2010
    • 799
    S50US 3.0L M3 Engine w/ 70k miles (overhauled)
    - New main and rod bearings
    - All new timing components
    - Rebuilt Cylinder head
    - Rebuilt Vanos Unit
    - New Belts, Tensioner
    - Spark Plugs, coil pack connectors, and coil packs
    - New gaskets and seals
    - New Water Pump, Thermostat, Metal Water Neck
    - All New Sensors (E30 Gauge temp, E36 FI temp, O2 sensor)
    - Euro Oil Filter Housing with Oil Cooler (AN-8 Lines and Oil Cooler)
    - New Air Flow Meter
    - E34 oil pump, pan and dip stick
    - Custom E30 S50 Wiring Harness
    - 413 Red Label ECU
    - 16" Cooling fan
    - JVT Stainless Steel Headers
    - E36 Throttle Cable
    - IE Offset Engine Mounts
    - Coolant Hoses
    - Light weight single mass Flywheel, with new clutch kit
    Things I I still need:
    - Brake Booster
    - Exhaust from headers back
    - Aluminium Radiator
    Am I missing anything?
    Thanks guys!
    --->>>1988 SETA 2.7i Build Thread (Turbo Prep)<<<---
  • Lof8
    • Oct 2006
    • 2827
    What transmission?
    S50'd
    Originally posted by TDE30
    What is this faggy shit I have happened upon?
    I can always live in a M3. Can't M3 a house.
    • Overlord475
      • Dec 2010
      • 799
      Originally posted by Lof8
      What transmission?
      Using a Getrag 260. So going to fab a trans mount and bend my shifter arm 15degs left.
      Thought I saw someone here on r3v selling the mounts pre-fabled for $100??
      • BustaRhymes325i
        Gaping Anus OG
        • Aug 2009
        • 243
        Make sure you have correct knock sensors, crank and cam position sensors. Mine had the wrong connectors.
        • Overlord475
          • Dec 2010
          • 799
          Will do,
          Though I am buying the engine already rebuilt and wired up for the E30 swap from Metrix Motorsports. So they should have it all right.
          Random question...
          Does cruise control and the in dash MPG gauge still work after this swap??
          • e30shmobberr
            • 1934
            Originally posted by Overlord475
            - E32 oil pump, pan and dip stick
            e34 btw. and dont forget the gaskets for all of this.
            Patrick - IG:niicknac
            RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, bagged
            • Overlord475
              • Dec 2010
              • 799
              Sorry, typo... Edit fixed
              Engine is already put together... Gaskets and all.
              • JJe30
                • 2044
                Easy mod you can do is light weight pulleys while the motor is out of car.
                • StereoInstaller1
                  GAS
                  • 22679
                  2 cases of beer
                  Closing SOON!
                  Thanks for 10 years of fun!
                  • ck_taft325is
                    • Sep 2007
                    • 6880
                    2 cases of beer
                    4 cases. 4...
                    Need a part? PM me.
                    • Overlord475
                      • Dec 2010
                      • 799
                      Beer check, lol
