So I used to have my old brown temp sensor from my 325e in the M50, assuming it would work, but it didn't. I assumed that didn't work because I now have a 325i gauge cluster. The old 325e sensor screwed right into the head.
So I got a new sensor to match my new cluster, supposedly from a 325i, but the PNs are the same anyway between i and e. PN# 13 62 1 357 414
This new one is waaaaaaay smaller, only thing the same is the plug/pins. The color is white/clear (instead of brown.) The new sensor will drop straight into the head without threading, way too small.
Has anyone else encountered this problem? I don't F'ing get it!! This is an OBD1 M50 BTW, no OBD2 machining necessary. I'm thinking I have the ECU coolant sensor for the M20 and threads into the block or something? I don't have an M20 to look around, but I think I'll have to bring the part back to the dealership on monday and bring my old sensor with.
