Driveshaft woes.
  • i3uller
    • 249
    Driveshaft woes.
    I have an 87 325is and am swapping in the m50 attached to an e36 5 speed. Here is a picture of what is going on. Any suggestions?
  • Stu Mc
    • 4083
    E30 or 36 driveshaft? If 250 transmission, you must use E30 M3 driveshaft.
    • i3uller
      • 249
      I'm using the stock driveshaft on my 87 325is with an e36 5 speed tranny. Non ///m i beleive.
      • Stu Mc
        • 4083
        That combo doesn't work. You need an E30 M3 driveshaft. Stock driveshaft can only be retained if you use the stock trans
        • 86325e
          • 228
          E30 trans, E30 diff……………………..E30 driveshaft
          E36 Getrag trans, E30 diff……………E30 driveshaft
          E36 ZF trans, E30 diff…………………E30M3 driveshaft
          E36 Euro 6-sp trans, E30 diff…..…….Shortened E30M3 or E36M3 driveshaft
          Eric
          85 325e M50 and auto to manual transmission conversion...
          • Stu Mc
            • 4083
            Bueller, you are using the correct driveshaft, my mistake. I confused the ZF and 250 gearboxes. What about the center section, can it be adjusted further?
            • i3uller
              • 249
              I'm not sure. I'm gonna look at it a bit more after doing some more work to get the engine start-able. But I like to hear that I have the correct driveshaft. There has to to be some way to shorten that gap up. What is the ZF tranny anyways?
              • 86325e
                • 228
                You can adjust the length a little. Just unscrew that nut deal on the driveshaft some and pull it apart a little. Thats what I did on mine and that closed up the gap fine.
                Eric
                • Addissimo
                  • Mar 2004
                  • 1820
                  I pulled the centerbearing forward, then if you pull hard enough on the forward part of the driveshaft you can make up the difference. It shouldnt take too much effort to do.
                  Your ecu will be there before 3.
                  -Addis
                  Doing something M50 related? -> http://www.addissimo.com
                  On Myspace? ->http://groups.myspace.com/r3vlimited
                  BF2142 SN = BillyGoose
                  • i3uller
                    • 249
                    -Addis
                    Have I told you that I love you.
                    • Addissimo
                      • Mar 2004
                      • 1820
                      -Addis
                      you just did- get your drive shaft to work?
                      • grapedrink
                        • 1514
                        So my late model E36 M3 trans needs an E30 M3 driveshaft eh? Would it change if I swap in the Z3M roadster diff?
                        Originally posted by DaveCN
                        Welcome.
                        Your car is a piece of shit.
                        Most of them here are, too.
                        • i3uller
                          • 249
                          -Addis
                          Drive shaft problem = solved. It's a thing of the past. All that is left now is to get the radiator installed, ecu installed, coolant res installed, do the wiring, and bleed all the systems. Almost there.
                          • Addissimo
                            • Mar 2004
                            • 1820
                            Nope- you'll still need the m3 driveshaft... its pretty much the same diff (my understanding that is).
                            -Addis
                            • grapedrink
                              • 1514
                              Well I just checked today and the E36 M3 driveshaft with my E36 M3 trans and E30 diff all work together. No need to buy an E30 M3 one.
                              Welcome.
