First off this is an s52 with obd1.I finished the swap months ago and other then a few minor problems the car ran great,I recently broke my pressure plate so the car has been on jack stands for awhile.I finally got it back together and now the car will not start.Cranks fine I checked to make sure all grounds and connectors are good,fuses are good but the fuel pump is only getting 1.2 volts when I crank.
My crank position sensor has resistance of .508 which seems a bit low but the car had no codes when i pulled it into the garage to do the clutch.The obvious would be I pulled a wire or something doing the clutch but I spent 2 hours checking everything over.Im not 100% where the fuel pump relay is ,I have 3 relays along the fire wall blue which i think is the isv white,dme? brown fuel pump?all relays are getting power out of #30.Any other sensors cause no power to the pump?
The car did have a starting problem once a day before I pulled the clutch I just installed my airbox and when i got in it would not start so I wiggled the hfm a few time and it started .Would hfm cause a no start issue or maybe just a coincidence?
