car starts...oil smells like paint thinner
  • Joe G
    • 2942
    I borrowed a working M50 ECU, now the car will start. But the motor has a slight knock noise, and the oil on the dipstick smells like paint thinner. I just put mobil 1 in 2 days ago...WTF?
    Current Car: 2011 BMW 135i, M-Sport, 6 speed
    Originally posted by lambo
    Sounds like you need a massage.
    Originally posted by kpeng
    Who the hell is Vlad?
  • Fusion
    • Nov 2009
    • 3659
    Sounds like you have fuel in the oil. Not good.
    • Joe G
      • 2942
      the knock noise was just flywheel chatter. How would fuel get into the oil?!
      • xwill112x
        • Jan 2009
        • 4236
        running way to rich and running down the cylinder walls.
        maybe a leaky injector.
        • nrubenstein
          • 3148
          Leaking injector, or cylinder not firing.
          2002 BMW M3 Alpinweiß/Black
          1999 323i GTS2 Alpinweiß
          1995 M3 Dakargelb/Black
          - S50B32/S6S420G/3.91
          1990 325is Brilliantrot/Tan
          1989 M3 Alpinweiß/Black
          • Joe G
            • 2942
            check injectors and do a compression test?
            yesterday i pulled a fuel line off after it was cranking with no turnover, and the line was infact full and it made a bit of a mess of fuel around the intake mani and valve cover. Is there anyway some of that found its way into the motor?
            Should i also drain all the oil and put some fresh stuff in?
            • xwill112x
              • Jan 2009
              • 4236
              if theres fuel in the oil..i wouldnt load it up badly..but i would think idling would be fine. deffinitly drain and fill before you drive the shit out of it
              • gazellebeigem3
                • Jun 2005
                • 3712
                I bet if you change the oil and it will be fine. I think you were just posting about the faulty dme not providing spark but had fuel pressure? you probably filled the cylinders up with fuel and it got into the earl.
                • Joe G
                  • 2942
                  ok. Oil flush will be the first thing i do tomorrow. Thanks all.
                  • ck_taft325is
                    • Sep 2007
                    • 6880
                    Flush and check your injectors. Spark plugs may be fouled also...
                    Need a part? PM me.
                      • 37832
                      Check the muffler valve converter.
                      Classic BMW Specialists
                      Grover Beach, CA
                      www.BimmerHeads.com
                      • ck_taft325is
                        • Sep 2007
                        • 6880
                        Head light fluid.
                        Need a part? PM me.
                        • Edev
                          • 3731
                          Exhaust fluid.
                          Wait..there already is that.
                          M Coupe
                          • e30gentry
                            • 608
                            Originally posted by Eric Devier
                            Exhaust fluid.
                            the new bmw diesels have exhaust fluid!
                            • Joe G
                              • 2942
                              ok so after 3 oil changes and about 150miles it still has a faint gas smell.
                              2 questions:
                              1) i deleted the charcoal canaster and im running that vacuum line with the pressure reg directly to the TB, could that be it?
                              2) im using OBDII exhaust manifolds, and they have the holes between ports 2/3 and 4/5, these holes were not plugged/hooked up to anything, could this be doing something?
