Background:
- '87 325e chassis
- '91 E34 M50NV running a 402 DME
- Modified E34 harness originally in an '88 325is for M50 swap
I had issues revving the car at idle or while driving, so I replaced the TPS with a junkyard unit that is in spec with no dead spots, according to my multimeter. Now the car revs at idle fine, but if I am driving, it sputters. This behavior only occurs once the car is out of cold start. I have another tested & good TPS as well as another tested and verified good MAF on hand. I sprayed carb cleaner around everything intake related in small sections to check if I had a vac leak, but the intake tract seems to be sealed. I also used a smoke bomb as a ghetto smoke machine test, and I have zero leaks with that on the intake and exhaust sides.
My guess is that my oxygen sensor is getting lazy. What else might cause this problem? The spark plugs are 7 mile old NGK BKR7Es. This is the only thing keeping me from daily driving the car again, so any and all constructive help would be appreciated!
- '87 325e chassis
