Finally got around to starting my S52 swap last week into my 91 318is, The engine I got was from a 98 M3 automatic and has a lot of unnecessary wires. Have any of you seperated the harness or do you just bundle the extra wires together. Also after going through the wiring diagrams a couple of times I came up with following functions on the x20 but would like others to take a look and see if I made some errors and a couple of these I am really unsure of. I will be keeping the car OBD 2 and having TRM disable the EWS and rear sensors etc. I have seen a couple of wire harness conversion charts for OBD 2 S52 but I guess they were for different years as they had a position 14 for road speed or oil level mine has no wire at all at 14.
Color Function
1) Blank -
2) Blank -
3) Grey / Violet ?
4) Black / Blue Compressor Control Relay
5) Black / White ? Pressure Switch (pg 100)
6) Violet / Grey Climate Control
7) Thicker Green Ignition Switch / EWS
8) Red / White (thicker) O2 Sensor 1 & 2 Heater Power
9) Brown / Red Traction Control / ABS
10) Blank -
11) Brown / Yellow Coolant Temperature
12) Brown /Violet Coolant Temperature
13) Green /Violet Fuel Pump Relay
14) Blank -
15) Black / Green Starter Relay
16) White / Yellow Data Link
17) White Violet DME Diagnostic Connection
18) Black / Yellow (thicker) Starter Ignition
19) White / Green Instrument Cluster Diagnostic
20) Black Engine Speed Signal
21) Thinner Green DME - Power
22) Green White (thicker) O2 Sensor 3 & 4 Heater Power
23) Brown / Green Oil Pressure
24) White / Black Fuel Consumption
25) Blue Alternator
I would appreciate any input.
Thanks,
Seth
Color Function
1) Blank -
2) Blank -
3) Grey / Violet ?
10) Blank -
14) Blank -
25) Blue Alternator
Thanks,
Seth
