So I think I'm all done and ready to go...but.....
1. My PS isn't working for some reason or another....I'm suspecting a bad pump... :(
2. My brake booster has a really bad leak in the diaphram I beleive...It hisses a crapload until I push the brake all the way down to the floor...the brakes work fine..but that hissing is throwin a code and not letting the engine run correctly... :(
3. And the best of all...I think there is a loose nut or something inside the bell housing...I can rev the engine all day long and it sounds and runs fine (minus the brake booster leak) but if I drive it and accelerate or there is any sudden jerk this ridiculously loud clanking comes from underneath the car and then it stops randomly...I think it's a nut just being moved into the flywheel and getting tossed all over the place in there and then it stops when it finds a resting spot again...:( :( :(
Any suggestions on any of these problems? :x
