Well, I have been working on this swap for quite some time now and I'd like to say thanks to everyone so far, because this is only the second time I have had to post a question.  Search has provided very many answers.
Turned the key for the first time just recently and the motor just cranks and cranks and won't fire.
Things I have checked so far:
I know my fuel pump relay is bad, I jumped it and it powered up but the motor still won't start.
I went back and checked this relay by hooking 12V to 30 and 85 and grounded 86 then put my test light on 87. It clicked and the light illuminated, so the relay is good.
My DME (Red Label 413) is getting power because my ICV hums and the Check Engine light illuminates.
I know my camshaft sensor is not swapped with the crankshaft sensor on the harness. I triple checked the wire colors before installing the harness and just checked the wires again now that it's all installed. (Ref. Post #52 for notes)
I am using the M44 crank sensor (12-14-1-247-62) in the stock S52 location per the advice I got in the only other question I asked. http://www.r3vlimited.com/board/showthread.php?t=185778 This is the only sensor I bought new so it should be good.
I'm not sure if I am getting spark, I suspect no, but I'm not sure why or how to know for sure.
Where should I look?
Any help is very appreciated. TIA.
Edit: IT STARTED! page 6 post 85 for video. Had to bypass E30 code immobilizer circuit.
