power steering hose help please?.
  • JRKOUPE
    • Dec 2004
    • 3159
    put the s50 in last season.....had a shop do it.
    using the OE e 30 rack....91 e30 325i
    How do I know what PS hoses are in the car, e36 or e30?...
    I know I can ask the shop( but the tech that did the work is gone)......
    Id rather figger it out myself...so I can order hoses/lines
    I have some leaks, and would like to replace all the hoses/clamps myself...
    does it even matter?...
    tia
    jrk
  • hammslice
    • 120
    The hoses look pretty different routing wise, but the ends are the same AFAIK. I think you can use either tho. Whatever will clear. I know I had to bend the low pressure side off the rack to clear the oil pan. I used the stock E30 lines.
    E36
    E30
    1990 332is - work in progress.
