i am so close to finishing my swap and ran into a problem. When i start the car, it starts up but gas keeps coming out of the rear and sounds like misfiring. its obvious there was huge signs of gas in cylinder 4 and 5 so i replaced the spark plugs along with the injectors. i checked the resistance of the injectors and it was 16.2 on all 6. so i turned it on agian after installing the injectors and spark plugs then the same thing still happens! so i thought the injectors might be bad so i switched around the injectors to see if it would change the cylinders that have too much gas covering the spark plugs. in attempt to find out what was wrong it turns out it was still in cylinder 4 and 5. so im guessing could i have fried my ecu and its constantly pumping gas into the cylinder? i know its not a cracked head because it was clearly fuel rather than coolant due to my gas tank emptying 1 gallon of fuel in around 3-4 minutes.
pleasee helpp me finish my swap so i can get it bar'd, thanks in advance
-robin
-robin
