S52: Compression Question
    I'm trying to source a S52 at the moment. I may have found one and was wondering if these compression numbers seemed okay:
    cyl 1 - 192
    cyl 2 - 190
    cyl 3 - 188
    cyl 4 - 191
    cyl 5 - 197
    cyl 6 - 190
    1989 US E30 Cammed S52
    Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
    looks good.
    Check Us out on Facebook
    Full Product Line Tuning
      I would also get a leakdown test if you can, (on a warm motor)
        Numbers look fine. S52 powa!
        -tim
        Originally posted by Jordan
        I like the stance
          last one I checked myself was 210, 210, 210, 208, 210, 212. this was on a motor that wasn't really warmed up.
            actuial compression numbers will vary depending on a number of things like altitude and such. The biggest thing to look at is spread/difference between cyls
              this is possitive news. thanks guys.
