The OFFICIAL heater core hose thread/answer
  • 328ijunkie
    • May 2007
    • 3961
    Got tired of reading back and forth about this so decided to tear one apart and see. As you can see the arrow points toward the valve from the core (IE: Top hose return, bottom from head).
    This is confirmed by looking at the design of the valve. Coolant flows into the valve from the core, goes up through the exit hole and leaves if the valve is open. When the valve is closed the hole is closed and the coolant force is being blocked by the plunger. if the coolant flow is reversed, when the valve is open the coolant flow will force the piston closed thus messing up your heat as youll get a fluttering sound as the valve continually opens and closes by the coolant flowing past it. You will also have intermittent/not working heat
    Unsure as to why BMW engineers designed the system to have hot coolant sitting in the core at all times but yeah.
    Also the solenoid is normally open. When voltage is applied it closes. (from the TIS its around the last 15-20 deg of the cold section of your temp selector on the heater control panel)
    So abridged version: CYL head hose goes to BOTTOM pipe of heater core. Hose coming from back of thermosat, whether spider hose or metal pipe goes to the TOP heater core pipe
    This is all assuming you have the common valve on top heater valve setup.
    Correct Install:
    Check Us out on Facebook
    Full Product Line Tuning
  • Philo
    Ich esse kleine Kinder
    • 3334
    Thanks for the definitive answer. Let's hope BMW kept this as a standard throughout E30 models.
    -tim
    Originally posted by Jordan
    I like the stance
    • 328ijunkie
      • May 2007
      • 3961
      Ninja Edit
      • herlsy
        • Sep 2009
        • 339
        This topic has caused me a headache over the past week or so. Had my hoses hooked up correctly, had an issue bleeding so the heater core pipes weren't getting hot which caused me to second guess myself and browse forums....bad idea. Switched them up, no difference.
        The other e30 board has a terrible 24v thread telling you that the hose from the back of the head must go to the valve.
        Not to be one of those to cause confusion, i will reiterate what the OP said:
        CYL head hose goes to BOTTOM pipe of heater core (without valve). Hose coming from back of thermosat, whether spider hose or metal pipe goes to the TOP heater core pipe
        Valve pipe: OUTLET
        Staight pipe: INLET
        • browntown
          • Jun 2004
          • 3524
          Now for all of us that never label anything or take pictures before a swap, we need a similar thread on which hard fuel line goes to which end of the fuel rail.
          • hammslice
            • 120
            I took some pictures and it was discussed in my "won't start" thread.
            http://e30sport.com/board/showpost.php?p=2446625&postcount=14
            http://e30sport.com/board/showpost.php?p=2446661&postcount=16
            1990 332is - work in progress.
            • Pussy30
              • Feb 2011
              • 463
              Ughhhh and make sure you do this when you put the motor. I bought my swapped car with it looped and running the hoses was impossible, theres no clearance unless you pull the intake manifold.
              • 328ijunkie
                • May 2007
                • 3961
                Yup!
                • justin_l_
                  • Jun 2007
                  • 1079
                  Bash it all you want, it is better than any thread you have ever contributed to the E30 community.:ohsnap:
                  • Mr.SWISS
                    • Nov 2005
                    • 1251
                    No we don't. It depends on if the rail is OBD1 or 2, and then its's pretty easy to deduce which line is the feed if you follow it from the fuel filter, and then LOOK at the rail and the line that DOESNT come from the regulator is the feed, on OBD2 the round metal tube on top is the return.
                    JEESUS FUCKING CHRIST This shit isnt that damn hard!!!!!!! HEAD TOP SPIDER BOTTOM !!!!:hitler:
                    Originally posted by 325Projectz
                    don't listen to the diagram... listen to mr. swiss.
                    :nice:
                    • 328ijunkie
                      • May 2007
                      • 3961
                      Uh did you just read the thread? Thats wrong.
                      • FredK
                        • 14752
                        Yeah, if it's TL;DR, then
                        SPIDER TOP
                        HEAD BOTTOM
                        • herlsy
                          • Sep 2009
                          • 339
                          Glad you took the time to browse my posts to justify your statement. Makes me feel worthy. Now be a good lad and update that other thread.
                          • e30s50dan
                            • Nov 2008
                            • 2076
                            ....I can just smell antifreeze from reading this thread lol!
                            NASA
                            BMWCCA member
                            PCA member 25yrs
                            1991 318IS slick top
                            1997 M3 sedan
                            2001 325CI DD
                            “whoever turns the wheel the least, wins"
                            • samiam3356
                              • Jul 2009
                              • 1901
                              For everyone in Australia its reversed!
                              What about the people with the Valve on the bottom? Is the valve made to flow different on those?
                              Originally posted by Roysneon
                              $5 shipped?
                              Originally posted by MarkD
                              You are a strange dude, I'n not answering any more posts from you.
