service indicator reset? anyone figure it out?
  • Jason89i
    • Sep 2004
    • 875
    has anyone figured out the wiring for the SI reset? its really driving me nuts. the reset tool is not getting power when plugged in. ive done (2)e30m50's and still have not figured this out.
    cheers, jason
  • Stu Mc
    • 4083
    I am also interested in the answer, my reset-tool doesn't work on my 318 or my brothers M3.
    • cheades
      • 632
      If you don't want the service indicator at all you can remove it very easily by taking out the cluster and just pulling out the service piece. Everything else will still work fine with it missing.
      • So Live
        • 2512
        Anyone get this thing to work? I searched and found next to nothing so i decided to bump this thread up.
        -Chris
        • Jason89i
          • Sep 2004
          • 875
          wow, thats an old post.
          e30 pin 11 (wht/blu) SI RESET signal from si board to diag connector. i have found this to be true on the 86es, 3/87m, 88i, 89is, 91is, 90m.
          e36 pin 19 (wht/grn) SI RESET signal from inst. cluster to diag connector. i have found this to be true on the 92e34, 94e36, 95e36, 95e36m, 98euro e36m3.
          cheers, jason
          • So Live
            • 2512
            So right now i have e34 pin 19 to e30 pin 16. Should i have 19 going to 11 and 16 or just 11?
            Thanks
            Yeah, I figured id keep the board a little bit cleaner and just bump this one.
            -Chris
            • FredK
              • 14752
              Just 11. The wiring diagrams that you find online are wrong.
              • So Live
                • 2512
                Awesome! I used addissimo's chart for the future people.
                -Chris
                • Jason89i
                  • Sep 2004
                  • 875
                  e36 pin 16 could be rdx data link or the static oil level depending on years.
                  not sure how many time i have to say this......there are NOT any correct / fool proof wiring diagrams on the internet. PERIOD. ultimately, you need the bentley /etms and a voltometer.
                  oh, since i did start this thread.....(two years ago, 6 e30's ago).....the problem was no voltage at the diag. connector.
                  cheers, jason
                  • So Live
                    • 2512
                    Hahaha, good call man. Its always nice to search for stuff and find answers and not just the same questions!
                    -Chris
                    • So Live
                      • 2512
                      It works. Thanks guys.
                      -Chris
                      • static
                        • Oct 2005
                        • 501
                        i read somewhere that it's possible to reset the Oil Service indicator by grounding some pins on the diagnostic port.
                        I searched but oddly can't find anything. Can anyone help?
                        • tonytony
                          Knee deep in poopie
                          • Jan 2004
                          • 3498
                          good for future reference, thanks for the info jason
                          • MIKe30
                            • Sep 2006
                            • 2334
                            having same issue. This cure all diagnostic port issues or just the reset tool?
                            I have a peake tool that is supposed to be able to reset, but it's supposed to read all codes too. Likewise, no power when plugged in. This a cure all, or just cure the reset portion?
                            I don't care about resetting anything, I want to be able to read my codes if there are any... stomp test isn't working either btw.
                            • MattM
                              • Apr 2009
                              • 931
                              wow, the OP was over 4 years ago! been bumped every 2 years.. LOL i would like to know this aswell becuase my SI board is blinking inspection at me right now..
                              Full Build Thread Here
