m42 starter the same as m50 starter?
  • trackjunkie21
    • Jan 2010
    • 3962
    Pelican is showing that the part numbers are identical for m50 and m42 cars, Wondering If I could reuse my starter. I'm going with an m50 flywheel,pp,clutch.
    Originally posted by Wh33lhop
    VANOS: sometimes you just need to go full retard.
  • trackjunkie21
    • Jan 2010
    • 3962
    Any help? They look identical and have the same specs but a different part number, number of teeth is the same etc.
    • Chris916
      • 183
      in for an answer. that would be awesome if i didnt have to get an m50 starter
      • ayemattyyy
        • Apr 2008
        • 411
        I don't know part numbers, but the flywheel/clutch relates which starter you should use. Therefore look for an m50 starter.
        Matt
