I have been reading around and have not found anything yet.
I have a non-abs 85 325e and an ix booster and master cylinder for ABS. The non-abs system has three lines to the master cylinder. My non-abs master cylinder that was in the car cannot bolt up to the IX diaphram, because the studs are in the wrong spot. Secondly the lines are too short.
I assume I can modify the lines, but is there a non-abs master cylinder for the ix diaphram?
Any other suggestions are welcome. Thank you!
Alex
Alex
