hyperextended slave cyl
  • Knoepfler
    • 631
    So I hyperextended a new clutch slave cylinder and then when I got a new one and installed it and drove the car around, there's a piece of it rattling around irregularly inside the tranny.
    What's the best way to get it out?
    Edit: and I have no idea what it is because the rod/rubber ring thing were still attached
  • iamsam
    • Jun 2008
    • 176
    I'd say unbolt the driveshaft, unbolt the trans from the motor, pull them apart while still in the car, attempt to retrieve parts w/ a magnet.
    • 328ijunkie
      • May 2007
      • 3961
      What trans you running? Fish it outta the Oil pan bolt holes in the bellhousing
      Check Us out on Facebook
      Full Product Line Tuning
