Is possible to run the crank from a m52b28 in an m52b25? I have a m52b25 and I was curious. The engines should be basically identical except the bigger crank in the m52b28, no?
Maybe a dumb question
I have one ;)
Check Us out on Facebook
Full Product Line Tuning
OBD2 Tuning Available! OBD2 E36, S54 Swap, S62 Swap, etc: tuning@MarkertMotorWorks.com Dyno ThreadComment
