Labeled diagram of m50nv ECU connector plugs?
  • Oz10
    • Jul 2009
    • 640
    Hey guys,
    I'm trying to find a labeled diagram of what each of the plugs between the ECU and wiring harness. I am not getting power at 6 of the plugs I'm supposed to. :curse: I've searched multiple forums, realoem, etc and haven't found one. But I know there's got to be one out there. Thanks for your help!
  • e30rapidic
    • 2167
    oil pressure sensor BRN/GRN or BRN/GRY
    front coolant temperature sensor (ECU) BRN/RED BRN
    rear coolant temperature sensor (Gauge Sensor) BRN/YEL BRN/VIO
    crank position sensor YEL
    cam position sensor YEL RED/WHT BRN/ORG
    VANOS solenoid RED/WHT GRN/BLU
    knock sensor, 1-3 BLK NCA DME PIN 70
    knock sensor, 4-6 BLK NCA DME PIN 69
    throttle position sensor (TPS) BRN BRN/BLK RED/YEL
    intake air temperature (IAT) sensor BRN GRY
    idle control valve (ICV) WHT/YEL RED/WHT WHT/GRN
    Evaporative emissions valve BRN RED/WHT or attach an 68 Ohm resistor to override this
    '87 325ic, powered by S50.
