Total newb here, had some questions after pulling the M50 out.
Background:
Bought a minty stock 84' 318i. 44k miles. Broken M10, auto, drum rear brakes.
Bought a swapped (M50NV) 89 car that had been hit in the rear. 4 door, 5 speed, discs, and of course the m50nv.
Pulled the motor out today, went pretty smooth. I started by pulling the intake, and trying to remove the entire wiring harness.....after I nearly did realizing it could stay with the motor :)....so it did.
Questions-
The transmission has 2 sensors, I would assume these are flywheel trigger sensors. It appeared that these were cut (RobertK did the swap iirc), although I'd like to confirm they wern't cut/squashed or snipped when I pulled the motor out. Hoping I didn't screw that up...they probably arn't cheap.
When I pulled the motor/trans out, I also noticed the guibo (sp?) on the trans had an arrow on it. I marked it to keep the position, but apparently the mark got rubbed off when I man-handled the motor out.....is this critical to alignment, or can I forget about this?
Tomorrow I get to pull off both subframes, the e36 steering rack, suspension, brakes, etc. Car came with some decent parts on it, so I plan on re-using as much as possible. A 5 speed/disc swap and 24V swap might be a lot for a first timer, but if I do one thing at a time I think I can do it. Later, perhaps some A/C, 5 lug swap, and maybe some boost. For now I want to make everything as CLEAN as possible.
-T
Background:
Questions-
-T
