s52 long cranking
  • crazyvwobie
    • 298
    s52 long cranking
    Need some ideas 91 318is s52 with obd1 Randomly cranks long and takes 2 or 3 tries cold or hot.Some days starts 1st try.Fuel pump is original with 120000,new spark plugs,and hfm.Car shows no other symptoms runs great no hesitations and idle is steady.I found lots of threads on this but no one ever seems to post their results.I do have a fuel pressure gauge and that seems fine when running except when It wont start the pressure is low and jumpy until it fires,so im certain its a fueling issue. Im leaning toward crank sensor and maybe fuel pump?
    leaning toward crank sensor fuel pump consistantly builds full pressure when I jump the relay
  • EduardoGomez
    • Feb 2011
    • 48
    Install fuel check valve after the pump on the high side, part number 16 14 9 068 988,
    I did that and it helped a lot
    • bimmerteck
      • 762
      Try installing a check valve from a 750il They run less than $10 and often solve long crank issues related to fuel if the check valve built into the pump has failed. ;)
      16-14-9-068-988
      edit- What he said^ :)
      • 87e30
        • Jul 2008
        • 5676
        Interesting, what about on early model cars?
        Is it wise to replace the pump under the assumption that the check valve failing means that the pump will fail soon?
        How big a role does the starter play in long starts?
        I just hate everyone.
        No need for discretion.
        • crazyvwobie
          • 298
          going to try this check valve before I go any further.thanks
          • nickmcc92
            • Dec 2012
            • 442
            Did you install the check valve? Results?
            • Gooch
              • Dec 2006
              • 1674
              Rather than post a new thread, anyone have any updates on this? I am experiencing almost the exact same symptoms as the OP. (Except I'm OBD-II and have a TRM fuel pump with less than 5k miles on it).
              '91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
              '87 535i - Vacuum brake conversion [SOLD]
              '93 525iT - 5-speed swap - 320k and counting
              '09 328xi - 6-speed
