Has anyone found a way to modify a e34 m50 oil pan so it doesnt sit as low? Being on air i cant go any lower because the oil pan is on the ground.
If the pan could be cut and rewelded so its further up or if metal was welded in to make it bigger width wise to keep the capacity.
