Please Help, Heavy Knocking, pinging, cutting bad idle
    I have rebuild my supercharged s50 and since then i can not fix this annoying problem . The engine has bad idle just like over-camed engine and extremely hard to drive. Under load the engine will start cutting pinging, knocking heavy, backfiring and the engine almost dies. This will happen every time more than 15% gas applied. So basically if i drive the car i can not push the gas pedal more than 15% otherwise the engine will start cutting and heavily knocking. Under accelaration when kconiking accours at 4,5 and six cylinders headers get super red and 1,2 and 3 do not get heat up so much. If gas is applied slowly, engine will slowly rev up to 5k rpm and start knocking again.
    I have:
    Changed the software to NickG
    changed fuel pump
    changed fuel pressure regulator
    changed fuel filter
    changed injectors
    changed ground resistor to the coils
    checked fuel pressure 45 psi at idle
    changed spark plugs
    AFR 19 at idle 14-12.5 3-4k rpm with a lot of pinging
    AFR are suppose to be high 14s at idle high 11s at high rmps
    no codes stored
    changed Air flow meter
    checked all vacuum lines 10 times
    checked all wiring 10 times
    changed Idle control valve
    and still the same problem.
    Could it be camshaft positioning sensor?
    What do you think could solve my problem?
    Thank you for your help as i'm clue less at the moment and most of the mechanics i know are to.
    Sounds to me like cracked coil insulator. Soon as there is some load on the engine coil spark will shoot across the coil plastic into valve cover instead of the spark plug.
