Hey guys,
I have been trying to troubleshoot a problem with my obd1 m52 swap for the past week or two. I was on the interstate last week gettin on it in 4th gear and noticed it wasnt pulling how it should. I got off the interstate and the idle was bouncy. You cant see it on the tach but you can feel it.
I noticed I have an exhaust leak and the tick is really loud but Im not sure if the leak just got worse because of the vibrating engine.
I started out by pulling the coil packs and the number 6 cylinder did not respond. I swapped the coil packs with no change and then checked for spark. It had spark so I then checked the fuel injector pulse using a noid light and swapped the 5 and 6 fuel injectors being everything checked out to that point.
Still had no change so I then did a compression test and had between 192-210 on all cylinders. I also pulled the valve cover because I was doing the gasket anyways and everything in there looked fine.
Stomp test shows code for 3rd ignition coil but swapping that produces no result as well. I have checked and cant find any vaccume leaks. May be worth noting as well that the plug is dry when I pull it.
