i do that so people see it, Im at a loss man, not sure what else to do, and its hard when there is no chart to confirm what the resistance on certain sensors should be.
Need help m50 NV 92, crank no start
Its dumping in to much fuel still?
After your plugs fuel fouled did you change them?
A fouled plug will give you a weak spark and a misfire. Drying them out doesn't work there don't always bounce back.
Have you tried disabling the fuel pump and priming the manifold with fuel to see if you can even get it to fire without the pump running?
Id rule out the cps because IIRC it will disable fuel and spark if its not workingLast edited by 416stroker; 04-24-2011, 10:52 PM.84 318I Delphin RIP
87 325IS delphin 24v Sold
89 325 AlpineweissComment
You didn't by some chance replace the harmonic balancer did you? NV and Vanos trigger wheels are different and will cause a no start. Just fishing.
'89 Alpine S52 with goodiesComment
I did not no, possible problem with adaptor, looking into now, on the phone emailing, and on skype as we speakComment
I remember why I hated the E34 ETM tonight. x-xComment
this is what I have, mine fired up first time.....luckily
e34 harness to '87 325i
oil pressure sensor BRN/GRN or BRN/GRY
front coolant temperature sensor (ECU) BRN/RED BRN
rear coolant temperature sensor (Gauge Sensor) BRN/YEL BRN/VIO
crank position sensor YEL
cam position sensor YEL RED/WHT BRN/ORG
VANOS solenoid RED/WHT GRN/BLU
knock sensor, 1-3 BLK NCA DME PIN 70
knock sensor, 4-6 BLK NCA DME PIN 69
throttle position sensor (TPS) BRN BRN/BLK RED/YEL
intake air temperature (IAT) sensor BRN GRY
idle control valve (ICV) WHT/YEL RED/WHT WHT/GRN
pin color description m50 pin
1 blue alternator 25
2 green/yello oil level (static) 1
3
4 brown coolant temp 12
5 brown/green oil pressure switch 23
6 green/white fused power O2 22
7 green ignition coil use large 21
8
9
10 blue oil level (dynamic) 2
11 white/green service lights reset 19
12 grey CEL 8
13 green/violet fuel pump 13
14
15
16 white/black SRS (unused) 17
17
18 black/yellow starter 18
19
20'87 325ic, powered by S50.Comment
Need a part? PM me.
Get your Bass on. Luke's r3v Boxes are here: http://www.r3vlimited.com/board/showthread.php?t=198123Comment
My adaptor had like the coolant temp wired into DME power, not sure what that would have made car to, jumping car soon AGAIN, and trying to locate legit pin out chartsComment
I also stand behind the hardwire option, but in a different manner, tie into the e30 m20 harness behind the connector. Then you still have an engine removal harness quick disconnect.Comment
If my DME is not getting power from my C101, will i still get fuel and spark?Comment
like starter fluid, and pulling fuel pump relay and fuse? yes I haveComment
no real fuel . put like a half a paint cap in the throttle body. If it evan wants to run is shold run for 3-4 seconds. dont use starting fluid thats stuff all bad.Last edited by 416stroker; 04-25-2011, 02:07 PM.84 318I Delphin RIP
