Can someone who has wired this up before please double check and verify my wiring so i don't catch my shit on fire. Car is an 89 325is engine is 92 nv m50
c101 X20
1 ---- 25 -- Alternator Charging
2 ---- 1 -- Oil Level (Static)
3
4 ---- 12 -- Coolant Temp Sensor (Gauge)
5 ---- 23 -- Oil Pressure Switch
6 ---- 22 -- 12V Feed for Diagnostic Plug
7 ---- 21 -- Ignition (Switched)
8 ---- 24 -- Fuel Economy
9 ---- 20 -- tach/engine speed
10 ---- 2 -- Oil Level (Static)
11 ---- 7 -- SI Reset
12 ---- 8 -- CEL
13 ---- 13 -- Fuel Pump Relay
14 ---- 14 -- Speed Signal
15 ---- 15 -- Starter
16 ---- 19 -- Diagnostic Plug
17
18 ---- 18 -- Voltage During Startup
19-----
20-----
Somewhere i read that pin 20 is supposed to be used for abs but my problem is that i dont have a pin 20. Any help would be appreciated as this is one of the final things keeping my car from running.
c101 X20
3
12 ---- 8 -- CEL
17
19-----
20-----
