m50 pre-swap questions
  • JT325is
    • Oct 2009
    • 1242
    For you guys that has experience with an M50 swap. I can get my hands on a 95 m50, already has a tranny, ecu, harness.. I know that I need an E34 oilpan. What else do I need? My question is what have you guys done to the M50 before planting it in your E30? Just want to know some basic info and knowledge beforehand and any ideas, suggestions, or input is much appreciated.
    - James
  • Matt-B
    The Waffler
    • 3856
    go the the 24v section, it says, read this if you wanna swap, please read it, I did
    • 328ijunkie
      • May 2007
      • 3961
      Search Please.
      Check Us out on Facebook
      Full Product Line Tuning
      • brokenbimmer533
        • 317
        Lets see, before I put the engine in my e30. I replaced:
        Crankshaft
        Connecting Rods
        Pistons
        head studs
        every gasket and seal on the damn thing
        many new bolts
        water pump
        all three timing chains
        all four timing gears
        all timing tensioners and guides
        belt tensions
        all three belt pulleys
        All completely necessary.
        • !kid
          • 1362
          ^ why the crank?
          :borg:
          • 2poor2tune
            • 50
            Crankshaft
            Connecting Rods
            Pistons
            head studs
            many new bolts
            water pump
            belt tensions
            not if you find a good running m50....
            i did the oil dip stick o-ring, oil filter housing gasket, radiator hoses, new mounts of course, oil pan gasket, valve cover gasket, all the little things that will leak eventually if they don't already. i wish i had money like the guy above though haha
            • brokenbimmer533
              • 317
              I built a stroker m50. Crankshaft was out of an s52 with an 89.6mm stroke. Bored out to 84.5mm with new wiseco forged low compression pistons and new Integrated Engineering connecting rods. Currently an M50B30:D.
              I had collected parts for about a year, all building up to this point (pulling the eta May 13th). Looking for deals and taking my time putting it together. Almost everything on the engine is new besides the head but that got a 3 angle valve job and new stem seals.
              Really though I would replace any and every gasket you can afford. If you put it in to find out its leaking oil, you will be kicking yourself for not replacing gaskets while it was out and easy to get to.
              Head gasket can be expensive cause you have to buy new head bolts as well. If you are not looking to spend that much money I would at least do a compression test or a leakage test to determine the condition of the current head gasket. Harbor Freight has leakage testers for like $40.
              I have an extremely bad case of while-im-in-there disease. A year and a half ago my plan was to put a stock m50 in my e30 and now look at where Im at.
              Like others stated before all this information has been covered. Build threads in the project section can be beneficial if you find a thread similar to what you want to do.
              • JT325is
                • Oct 2009
                • 1242
                helpful information! really appreciate it guys
                • JT325is
                  • Oct 2009
                  • 1242
                  put up a video of your car, want to see that beast
                  • Adrian_Visser
                    • Jun 2006
                    • 2823
                    Or be like me and replace all gaskets and seals and still have a fucking leak.
                    PS: Use some forma gasket or Hylomar around the front timing cover to block gasket, especially in the corner it meets up with the oil pan. FML leaking synthetic oil at an alarming rate sucks.
                    '89 Alpine S52 with goodies
                    • highoutput
                      • Apr 2011
                      • 94
                      Im going to carry on th OP's question, cause I'm doing the same swap right now. The oil pan confuses me. People say you need an E34 oil pan, but its my understanding the some M50's came in E34's. So if you have an E34 M50, do you not need to change the pan??????
                      and how do you know?
                      24V M50, M3 cams, Turner Tune, full exhaust, ect....
                      • bimmerteck
                        • 762
                        You need to specify where your donor motor came from, otherwise it's very hard to help you. If your donor motor came from an e34 than it would have had an e34 pan on it while it was in the e34 chassis. assuming no one has removed it you are good to go, if the donor motor is from an e36 you will need to source and install an e34 oil pan, pump pickup tube, and dipstick assembly.
                        • brokenbimmer533
                          • 317
                          e34 oil pan has the main capacity of oil in the front of the engine, near the belts (front sump)
                          e36 oil pan has the main capacity of oil in the rear of the engine, near the transmission (rear sump)
                          • iceman
                            • Jan 2011
                            • 149
                            It will take 25 times longer than you plan
