i swapped a vanos m50 into my 89 325i automatic. my tach doesnt work. how do i fix it? i cant find the c104 plug because i dont think my car has it sooo what do i do? ive searched everywhere
tach
well idfk why its not working. pin 9 from the m20 side is going to pin 20 on the 24v side like it should, fuses are good. no c104 connector in the glove box. one thing that is weird is that my service indicator lights are always on when the car is on. is that how it always used to be?Comment
bump. i am having the exact same issue and i cant figure it out. I redid 100% of my wiring today and made sure that they were all correct according to the ETM's
FYI: Caris 89 with 97 S52 OBD1 w 94 m50 harness.1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IPComment
is the tach not working period or idleing too high? if idleing to high you have to change the switch on the cluster to a 6cyl" I'm not racing, I'm driving asshole"
:hitler: Das FührerComment
go back and look for an XX/89 wiring diagram for your build month and do the same for s52 instead of following a guide if that's what your doing. It could just be a different connection for your chassis/drivetrain.UNDER CONSTRUCTION - 24v 325e (future DD), DD 525i
stripped out e30 rally project - in progress
M50NV -> M50TU E34 swap underway
run a ghetto wire from the ECU pin: 47 to the cluster pin: 7 on connector C1 (black wire)
See what happens.
Check Us out on Facebook
Full Product Line Tuning
OBD2 Tuning Available! OBD2 E36, S54 Swap, S62 Swap, etc: tuning@MarkertMotorWorks.com Dyno ThreadComment
