spacing swaybar mounts
    ok, admitting defeat on this part.
    I have clearance issues between my oversize swaybar and Raceland header. I know some of you guys are running swaybar mount spacers. Any DIY ideas to resolve this or spacers for sale? I'm running out of time and need to lock this thing up! Gotta have to ready for The Vintage.
    '87 325ic, powered by S50.
    I have clearance issues between my oversize swaybar and header. I know some of you guys are running swaybar mount spacers. Any DIY ideas to resolve this or spacers for sale? I'm running out of time and need to lock this thing up! Gotta have to ready for The Vintage.
    Which headers are you running? Racelands? Euro headers?
    The stock manifolds and the ebay headers shouldn't require a swaybar spacer.
    INSTAGRAM: @UNDR8D_EMPIRE
      Racelands
        Interested in the outcome, I'll be facing this problem as well since I bought Racelands and have ST sways.
        Hows the subframe and CAB clearance? I have THR eyeball arms so I'm not really worried about that, but I have read about subframe modifications to make the Racelands fit.
        '91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
        '87 535i - Vacuum brake conversion [SOLD]
        '93 525iT - 5-speed swap - 320k and counting
        '09 328xi - 6-speed
          i'm thinking about trying the raceland shorties. any feedback on those? If they clear ok up in the engine bay the down pipes should be pretty painless to modify for clearance vs modding the header itself.
          I don't always wreck cars, but when I do I wreck them into trees.
          91' 318is S50 swap - The Black Widow
            I just did this PITA install today. I spaced my Engine mounts to raise the motor a bit to clear the subframe. I had to knock in a bit of the collector to have the sway bar bearly clear. They cleared my THR CAB just fine. I still need sway bar spacers. Where can I get sway bar spacers?
            95 7.1L 16V E36 M3
            Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
            LIKE my Facebook Page! CLICK HERE
