M42 radiator wiring in early model former M20 car?
  • Jand3rson
    • 37587
    Hey guys, got a few questions about wiring an M42 radiator in with my M50 swapped car, formerly an '86 325e (M20 car).
    So this is the wiring that used to connect to my old radiator, and those connections were on the driver side:
    These are the sensors that those wires connected to, on the old radiator:
    And this is the lone temp sensor on the M42 radiator, passenger side:
    So obviously that temp sensor has to come out and one of the ones from the old radiator has to take it's place, correct? And that wiring is going to have to be extended to reach the passenger side. My first question is, which one? Second, what was the other one for, and can it be discarded? Was it for the AC fan?
    • 37833
    Josh, you don't need to hook up any of that wiring for your swap.
    Grover Beach, California
    BimmerHeads.com
    • jrdeamicis
      • Nov 2008
      • 956
      If he wants to use the stock wiring for the aux fan he does.
      Past Car : E30 S50 6 Speed 5 Lug 3.73
      Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
      ___________________________________________
      BNB Designs
      Engine Swaps, Fabrication, Innovation, General Repair
      Richmond CA
      Julian 848-248-8029
      • browntown
        • Jun 2004
        • 3524
        I can't help, but I was under the impression all the radiator wiring was body harness side and it would hook up the same regardless of the engine sitting in front of it. no?
        • Jand3rson
          • 37587
          Ooooooh, that's all to control the fan, isn't it? So if I'm running an aftermarket electric fan, I won't need any of that then, right?
          • jrdeamicis
            • Nov 2008
            • 956
            No, but you do need to put a temp sensor somewhere to switch the fan.
            BNB Designs
            Richmond CA
            Julian 848-248-8029
            • Jand3rson
              • 37587
              So is that what the one sticking out of the side of the M42 radiator is, in the last pic? If so, do I just swap the one out of the old radiator in its place, and extend the wires over to connect to it?
              • jrdeamicis
                • Nov 2008
                • 956
                The new 3 pin connector temp switch will work fine. If I remember correctly it should be a 12V send and then one pin is HIGH and one pin is LOW. You can just wire the control from the switch to your fan relay.
                BNB Designs
                Richmond CA
                Julian 848-248-8029
                • JTapper
                  • Sep 2009
                  • 847
                  This is correct.
                  I wired twin slim fans to the factory wiring. The low temp switch turns one fan on and the high turns on the second. This also made it so I can press the A/C switch and power at least one fan regardless of coolant temp. Wiring this way is super clean.
                  Turbo Cabrio project: http://eurowerks.org/showthread.php?t=19677
                  • Jand3rson
                    • 37587
                    So I need to get the wiring connector that goes into that sensor? Because I don't have it.
                    • jrdeamicis
                      • Nov 2008
                      • 956
                      If I dig deep enough in my bins and bins of wiring I am sure I can find you one.
                      BNB Designs
                      Richmond CA
                      Julian 848-248-8029
                      • Jand3rson
                        • 37587
                        Cool, thanks! Let me know, and I'll pay you for it, if you want.
                        • jrdeamicis
                          • Nov 2008
                          • 956
                          Originally posted by JTapper
                          This is correct.
                          I always like running a low temp coolant fan. Just keep it out of mind. My car deals with it self. Not me dealing with the car....
                          And janderson, I will work on finding it tomorrow.
                          BNB Designs
                          Richmond CA
                          Julian 848-248-8029
                            • 37833
                            If you want to hook the electric fan to an OEM sensor you will need to run the wires. You'll need a different lower temp sensor for the radiator though. If it were me I'd just run a simple aftermarket fan controller.
                            Free Shipping - Flex-A-Lite Adjustable Electric Fan Controllers with qualifying orders of $109. Shop Fan Switches at Summit Racing.
                            Your local auto parts store will sell something similar too.
                            BimmerHeads.com
                            • browntown
                              • Jun 2004
                              • 3524
                              I'm so confused, I just went into the garage and pressed the a/c switch on my m20 that doesn't have any a/c or condensor fan anymore, and the engine still changes pitch like it is running differently. Clearly I don't understand the fan wiring and will shutup now.
