Hi Guys,
It looks like the opportunity has finally presented itself. A well maintained 1995 m3 has recently been wrecked in my province (one of only a couple in the entire province), and it seems like if I am going to do an S50 swap, this is the time to do it.
That being said, I am not mechanically inclined so I will need to have a shop do the work.
I have started this thread to document the progress (it will likely be a long drawn out one) as well as to ask for help and advice as I carry along. I know there are many informative threads out there which I have started reading, however this thread will allow me to gather information and discuss issues specific to my situation.
The Donor:
1995 m3 - buying the full car (probably in the vacinity of $3K)
The Shop:
My prefered mechanic has told me to budget 80 hours of labour to account for any problems they encounter. This works out to $5K in labour alone. This seems high to me. He said that if I could bring in a step by step for them, it might make it easier. Does anyone know of a write up that would be best to print off and bring to him? Possibly this one: http://www.e30dohc.com/wiki/index.ph...HC_Swap_Basics
Considering I will have a full Donor car, what other parts do you suggest that I swap over?
Part List Status:
S50 longblock with accessories- OBTAINED
S50 wiring harness- OBTAINED
DME- not sure what the m3 has- (need to confirm)
Smaller diameter brake booster- NEED
e34 325i oil pan, dipstick tube, dipstick, oil pickup tube- NEED
E34 throtle cable- NEED
E36 engine mount arms- I am hoping I can use the ones from the 95 m3
E28 535i or M5 engine mounts- NEED
Questions:
Driveshaft- what should I use here? the e30 325i or the e36 m3?
Wiring Adapter- Is it worth buying a pre-wired adapter?
Exhaust- I have an e36 m3 Borla cat back collecting dust- will this bolt up correctly?
All input, suggestions, comments and answers are very much appreciated.
Finally, here is a pic of the car that will be getting the S50:
The Donor:
The Shop:
Part List Status:
Questions:
