Difference with stock MC and iX MC
    I am swapping my iX booster out with a 944 one (my booster was bad). Now I have the iX MC on car now. I still have my stock MC.
    Which MC would be better with the 944 booster, if any?
    I have the rx-7 front rotors if that makes a difference.
    Thanks!
    I guess I will install the booster with the iX master for ease of install, and see if I like it. Unless someone could point out the differences.
      I had a 318is, used the IX booster and master, if I used the 318/325 1, it was going to touch intake boot...so I had to use the IX one
        Thanks Matt, but I was referring to the master cyl alone as I'm swapping my iX booster for a 944 booster but didn't want to swap the master cyl.
        I figured it out today so if anyone ever needs to know here is the info.
        The iX master cylinder has a larger diameter at the mounting point so it won't fit the stock e30, 944, or any other booster which has the same diameter as the e30. I had to go with the e30 one an may upgrade to the m5 one, soon.
