iX booster questions
  • bmw2002tiiagave
    • 501
    I know many have asked about the iX booster stuff, but I did a lot of searching and still haven't found a solid answer to the remote reservoir problem.
    I know all the parts necessary. 1) 2002 reservoir 2) rubber / cloth braided lines 3) grommets for the M/C
    The question is, what elbows or L shaped fittings do I use? I'm referring to the fitting that connects the M/C to the reservoir lines. I've seen many iX / 735 remote booster setups but most of them don't say what L shaped fittings they used.
    Thanks!
    1972 2002Tii
  • Gooch
    • Dec 2006
    • 1674
    Master cylinder elbow - 34321102282 x2
    '91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
    '87 535i - Vacuum brake conversion [SOLD]
    '93 525iT - 5-speed swap - 320k and counting
    '09 328xi - 6-speed
    • herlsy
      • Sep 2009
      • 339
      Also an option is the e32 740i or e34 540i elbows. It doesn't look like they are available as an individual part so usually just a junkyard part i guess. I used them on my setup and they worked great.
      • e30s50dan
        • Nov 2008
        • 2076
        btw...I used an IX booster(NO SPACER),E34 MC AND E34 reservoir...and it clears fine..I slotted the bottom firewall hole a little so the whole thing sits down a touch
        NASA
        BMWCCA member
        PCA member 25yrs
        1991 318IS slick top
        1997 M3 sedan
        2001 325CI DD
        “whoever turns the wheel the least, wins"
        • bmw2002tiiagave
          • 501
          thanks guys. gonna try that elbow part#
          1972 2002Tii
          • etxxz
            • Feb 2006
            • 2085
            IX MC and resevoir also work here. They are the same, or nearly identical.
            The e34 booster can also be used with spacer, or preferably without spacer, but needs the same rod modification (shortened in a sense)
            No more e30s for me.
            88 black BMW OBDII 332is dedicated track [sold]
            88 BMW OBDII bronzit 332is [RIP 03/08]
            91 BMW 325i [sold]
            86 Corolla 'Ae86' HB 20v trd [sold]
            http://youtube.com/watch?v=pTj7Hn9v5Rs
