Clutch and Flywheel for 240 Trans
  • Slovik
    • Jan 2010
    • 198
    Hi All,
    Just getting ready to pull my M42 out and swap in a 98 S52. I will be using the 240 trans from my 91 318is. I read that resurfacing the dual mass is a bad idea /or can't be done, I would really like to keep the stock flywheel (it works with my starter). I can buy a new one for about $675 along with the stock clutch for an e36 will this work with my trans? I know a number of you have kept your 240 but used the single mass m20 flywheel machined on back for clearance but I want to stay with a stock weight as this will be a street only car and would rather have smooth off the line starts. Any and all opinions would be appreciated. http://cgi.ebay.com/ebaymotors/SACHS...Q5fAccessories
    Thanks,
    Seth
  • trackjunkie21
    • Jan 2010
    • 3962
    Originally posted by Slovik
    Hi All,
    Thanks,
    Seth
    Why would you buy a brand new flywheel? and one for 675 for that matter? I bought a dual mass e36 325i flywheel and clutch setup. The m3 won't fit in the bellhousing.
    Originally posted by Wh33lhop
    VANOS: sometimes you just need to go full retard.
    • Slovik
      • Jan 2010
      • 198
      I was under the impression that the e36 and the M3 flywheel were pretty much the same the same, M3 is a few pounds lighter, what clutch did you use and did you get the e36 325 flywheel new or did you resurface it. Will this combo work with my trans...
      http://cgi.ebay.com/ebaymotors/F1-ST...Q5fAccessories
      Thanks,
      Seth
      • trackjunkie21
        • Jan 2010
        • 3962
        dude, just search. there is info all over this site
        • lifeiskaos
          • 1709
          m3 flywheel/clutch won't fit in the 240. use m20 clutch/flywheel/starter. it's light and cheap.
          • blackhawkimpact
            • 2415
            ^This
            • Leo_328i
              • 226
              Since we're on this topic...
              Just to clarify - what throwout bearing can I use? I know its been said so often to use the 323i throw out bearing but does a normal 325 one not work? And which M20 clutch do I use? 325i clutch kit or 325e (both for single mass flywheels).
              Leo.
              E30 318iS, E36 328i
              • blackhawkimpact
                • 2415
                You have to get a SMF and shave it. Or get a euro 323i flywheel like I did. No shaving needed.
                • lifeiskaos
                  • 1709
                  323i TOB, 325i clutch, shave flywheel ~1/4" or grind away some of the sleeve around the long bolts on the back of the oil pan.
                  • Matt-B
                    The Waffler
                    • 3856
                    a 323i TOB and 325i TOB ( e30 ) are the exact same
                    Im using s 325 TOB, single mass fly, 325i clutch kit, 240 slave cyl, 240 tranny
                    car runs funs and drives fine
                    • Hobbes
                      • Sep 2009
                      • 29
                      Lies. I had them side by side before I did my swap. My 325i (m20) clutch kit came with one and I had bought a 323i TOB seperately. Somewhere on the interwebz, someone took a picture of them side by side. They ARE different.
                      If the 325 one works, I would use it. I used a 323i TOB and it was an extra $80 that I apparently didn't need to spend. I think it would just move the enagement point in the pedal. I like how mine is though. I wouldn't change it.
                      • Kingb
                        • 928
                        you use the pilot bearing for your tranny the i.d. of the crank is the same. you just have to use the one that fits your tranny
                        Originally posted by Nicademus
                        My car beats off to that car. :bow:
                        • drumad
                          • Aug 2009
                          • 1700
                          Matt and I discussed this before and I ended up using the 323i euro TOB as well. The part numbers matched which didnt make sense to me either. I havent driven the car yet so I can't comment as to it working or not.. hah. I'll dig up the old convo when I get home.
                          2008 335i - n54b30
                          1991 318i - m52b28
                          1994 fzj80 - LAND CRUSHER
                          • Alpine e92
                            • 182
                            Can you use the m42 clutch and flywheel with the 240?
                            • e30s50dan
                              • Nov 2008
                              • 2076
                              ^ you can but why..do what they said above...M20 shaved sach clutch/pp/323to bearing/ m20starter. E a s y ! This is what I'm running with my S50
                              NASA
                              BMWCCA member
                              PCA member 25yrs
                              1991 318IS slick top
                              1997 M3 sedan
                              2001 325CI DD
                              “whoever turns the wheel the least, wins"
