I never really noticed this until i rode in a buddies e36....it was alot smoother than mine. I know its a shot in the dark, but heck, this is what this forum is about.
SYMPTOMS:
When deccelerating in second gear from 4000rpm down to 1800rpm, if you lightly squeeze the gas pedal there is a hesitation. it is not a smooth transition from "throttle off" to "throttle on." engine decceleration feels like "engine braking" rather than the smooth throttle off of other e36's.
somtimes i get a few small backfires at 3k.
I have also noticed that when i rev the car over 4000rpm and let the rpms fall to idle......all 6 injectors cut off at 2000rpm until idle speed, then the all start up together.
CHECKED:
Injectors not stuck (stethiscoped em)
o2 sensor is reading (stoich meter normal)
has newer tps
different hfm no change
GUESSES:
the vehicle speed reference signal is not getting to the ecu......????
SYMPTOMS:
CHECKED:
has newer tps
GUESSES:
