M50: Bad idle when TPS connected
  • lolcantturn
    • 4588
    I'm a 100% noob at the M50 motor, but I think I have all the vacuum lines attached right.
    The only thing not on is the charcoal canister, the lines to it are hanging freely and the purge valve isn't connected
    Certain times when I'm just idling, the car will momentarily die and then the idle picks up at :05, I was lucky to catch it on video.
    I know I have an exhaust leak before the O2 sensor.
    Also have a check engine light. Not sure how to really diagnose this.
    The engine is pretty responsive eitherwise.
    Any ideas?
    UPDATE: I couldn't narrow down any vac leaks but I figured out that if I disconnected my TPS my idle greatly improves. But I can smell the richness my engine becomes. Any ideas?
    Originally posted by TSI
    OEM+
  • matt
    • 3732
    You can stomp test the CEL.
    Hit the gas pedal all the way to the floor then all the way back to zero five times after keying the car on (don't start it)
    • lolcantturn
      • 4588
      Stomp test didn't work :/
      OEM+
      • cabin
        • Dec 2006
        • 552
        You said the charcoal canister isn't connected, do you have the port on the throttle body plugged? If not, there is one vacuum leak...
        -Justin
        Current: BMWless for now... '15 Grand Cherokee & '03 Mach 1
        • matt
          • 3732
          It's tricky.
          • Jand3rson
            • 37587
            I noticed mine wasn't plugged right before I mounted my throttle body up (no charcoal canister on my swap), and I just stuck a little black vacuum cap over it, you'll definitely want that port either plugged or connected to the canister.
            • lolcantturn
              • 4588
              Port is plugged there
              Originally posted by matt
              It's tricky.
              Trickier than M20? I could get the stomp test to work on the M20, but I can't for the life of me get it to work here. Mine is a NV motor if that helps
              It's plugged :/
              Like it's not even that my idle is crazy unstable, the engine literally shakes the car on idle, and I'm on decently soft E34 mounts
              OEM+
              • lolcantturn
                • 4588
                One other piece of info: I'm running my friend's NV ECU which I think may be setup for a lightwheel flywheel, he doesn't know if it is either. Maybe that's contributing to something?
                Something I noticed was, if I'm cruising around town at lets say 1500rpm, and I come to a stop, my idle will be PERFECT. Then it will die and pick up (like in the video) except the idle will be fucking terrible.
                OEM+
                • trackjunkie21
                  • Jan 2010
                  • 3962
                  It's a vacuum leak, I'm having a similar problem right now. Just started today =/
                  Originally posted by Wh33lhop
                  VANOS: sometimes you just need to go full retard.
                  • lolcantturn
                    • 4588
                    Shit sucks, driving me kind of nuts haha.
                    OEM+
                    • trackjunkie21
                      • Jan 2010
                      • 3962
                      Does the car feel like it has no power under load?
                      • lolcantturn
                        • 4588
                        Nope, runs strong as all hell.
                        OEM+
                        • M-technik-3
                          • 18946
                          Let me get this straight your engine is a m50b25tu yet you are running a m50b25 ecu? I would say that alone is part of of your issue.
                          When you drove to gutten which ecu did you have? There was no mention of issue then.
                          • mr2peak
                            • 2388
                            Do you have a lightweight flywheel? Mine surges at idle when the A/C or heater is on. Most afermarket chips that are set up for a lightweight flywheel raise the idle to get around the problem. Your idle s pretty low so I'm guessing it's not a lightweight chip.
                            Drive it hard. Maintain it well.
                            A Topless Memorandum
                            • lolcantturn
                              • 4588
                              nooo my M50 is NV as well. And I used that same ECU, my idle problem was still there but I thought it was cause of the torn-to-shit intake boot, which I replaced
                              Come to mention it my friend's M50 with the ltw flywheel idles at like 900rpm while mines pretty low
                              OEM+
