I'm having a hell of a time getting my cooling system bled. I have an M50NV with an M42 rad. Stock thermostat (I think) which I drilled a small hole in at the 12 o'clock position.
My procedure:
Jacked the front end in the air about 18" then filled the rad until it wouldn't take any more (approx 2 gallons). I'm running the car with the bleeder closed and the cap off the radiator.
I start the car and let it get to temp (3/4 mark on the dash, infrared temp gun shows the head being right around 200) at this point the expansion tank starts bubbling and the level rises greatly. Ive been placing a large funnel on top of the rad fill and I'm probably getting 2 quarts of coolant in the funnel, the level continues to rise and I turn the car off for fear of overheating. within two minutes of turning the car off the level abruptly drops all the excess it has risen, and when I say abruptly I mean like you just pulled the drain plug in the tub. As the level is rising in the exp tank I'm hearing popping noises and they are clearly felt by putting your hand on the radiator. sounds like a pissed off monster inside the rad is trying to get out.
Through this process I'm not getting any hot air inside the car and the radiator is still cool to the touch. Both upper and lower radiator hoses are quite hot and the line coming from the exp tank is scorching hot.
Ive tried keeping the radiator closed up with the cap on and seemingly nothing happens. Opening the bleeder only gives my coolant and the car just continues to get hot. No bubbling occurs with the cap on and the level can't rise. I tested the thermostat in a pot of boiling water for proper operation and everything checked out okay.
What am I doing wrong?
My procedure:
