I have a Bavauto rising rate AFPR sitting around and was wondering if I should use it in my S52 swap. I'm running the OBD1 conversion, a 3.5" MAF with 24# injectors and the TRM tune. I also have a pressure gauge that I can mount inline to see what pressure I'm at.
I called Bavauto and they say that the max flow rate has been tested to be ~60# without vacuum so I think it should be fine with 24# injectors.
Would it be beneficial to install this unit? If so, would I have to change the TRM tune? Please discuss all thoughts of using a rising rate AFPR vs. not using one.
