So ive got the infamous VSS code/cutting out issue,
From the ECU connector Blue/yellow all the way to the OBD1 413 pin 42 i have a clean connection yet still am getting the code randomly. Car is an 88i and has the VSS wire at the c101 pin 14. As i mentioned i even back traced it all the way from the cluster to the ECU and the signal is making its way there just fine.
What say you R3v.
What say you R3v.
