Slight random engine knock under hard acceleration?
  • ck_taft325is
    • Sep 2007
    • 6880
    Anyone else get that when in, say 4th gear at 3,000rpm accelerating to say 5,000rpm and having a slight engine knock on their S50? Just curious as it's not steady or constant just every now and again while passing someone on the freeway I'll get a slightly diminished power curve and some rattling from what sounds like the bottom end almost. Imagine lugging the engine slightly while going up hill in 1 gear too high for the grade. It's just like that but it is not consistent and generally if I just goose it a bit down the road at the exact same rpm's it's just fine?
    Curiosity more than anything.
    Need a part? PM me.
  • E30SPDFRK
    • 5707
    Could be detonation. There isn't a single good knocking sound lol.
    Byron
    Leichtbau
    • ck_taft325is
      • Sep 2007
      • 6880
      Hrm. School me on detonation? Bad tune? Failing spark plugs? Bad injector? I think that could have a million causes.
      Need a part? PM me.
      • Adrian_Visser
        • Jun 2006
        • 2823
        Your knock sensors are supposed to prevent detonation. Are you getting a knock sensor code that would indicate that they aren't working?
        '89 Alpine S52 with goodies
        • Farbin Kaiber
          Lil' Puppet
          • 29502
          Are you running 91? Add a full tank of premium and some octane booster and try to replicate the issue.
          • ck_taft325is
            • Sep 2007
            • 6880
            Only premium goes in currently. 91 Octane.
            Both knock sensors are new on the top end refresh. Actually, I might be lying about that. I think I replaced both but maybe just one got done. Fffffuuu.
            Need a part? PM me.
            • gobuffs
              • Dec 2004
              • 513
              Rod knock? Spun bearing?
              • Farbin Kaiber
                Lil' Puppet
                • 29502
                So the bottom end is as good as the top end was? All gone through, right? :rollseyes:
                • ck_taft325is
                  • Sep 2007
                  • 6880
                  I wouldn't think so. I'll see if I can't dig up pictures of the bottom end via oil pan off and of the pistons themselves when I had the head done. It all looked fantastic. Something to note is the VANOS is rattling around 3,000 pretty much all the time currently.
                  Need a part? PM me.
                  • ck_taft325is
                    • Sep 2007
                    • 6880
                    It was the MAF sensor.
                    Need a part? PM me.
                    • Adrian_Visser
                      • Jun 2006
                      • 2823
                      Phew!
                      • ck_taft325is
                        • Sep 2007
                        • 6880
                        Originally posted by Adrian_Visser
                        Phew!
                        Tell me about it. That MAF sensor turned down really threw me off. It's one of those things I just completely over looked in poking around. Car has no more down low rattle that's random, runs stronger and smoother. I also found that two wires in the boot (which has become quite worn) where bare wire and nearly contacting. So, I remedied that and changed out brake lines, rotors, calipers and pads. She's tip top again ;)
                        Need a part? PM me.
                        • giantkeeper
                          • Aug 2009
                          • 1416
                          You referring to the position of the sensor?
                          Always Always go for the reach around if there is an option
                          • ck_taft325is
                            • Sep 2007
                            • 6880
                            Yup.
                            Need a part? PM me.
                            • giantkeeper
                              • Aug 2009
                              • 1416
                              Yup.
                              I assume it was down and you turned it up?
