starter problem
  • isra
    • 177
    starter problem
    hi guys, i just finish my swap, but now i think i have starter problems i need help.
    i turn the key and grinding noises coming from starter y turn the crank to se if it would get the flytwheel but nothing.
    someone pls help i have a m52 with zf320tranny+m20 flywheel & clutch i used the starter that came with the m52 i also have the m20 starter but they looked the same to me so i used the m52 starter since it was working great.
    pls help thanks
  • 328ijunkie
    • May 2007
    • 3961
    use m20 starter.
    Check Us out on Facebook
    Full Product Line Tuning
    • ACHTUNG
      • May 2005
      • 2397
      Originally posted by 328ijunkie
      use m20 starter.
      This is correct since you're using the M20 flywheel you need to use the M20 starter.
      1989 US E30 Cammed S52
      Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
      • isra
        • 177
        car turned on today thanks matt-b an everyone.
        now i have another problem.. lol my cluster does not work at all any ideas?
        • isra
          • 177
          forgot to say my car is a 1986 325es
